Magister76
Jul 23, 2016Tutor
How to change the router's MAC address
Hello, I want to change the MAC address for my Netgear Nighthawk router. I do not see any option for this in the router's configuration menu. I know that this is possible with other Netgear rout...
Magister76
Jul 24, 2016Tutor
That makes perfect sense. Thanks again. Now I think I want to buy a separate router and cable modem. I really like the features of the Nighthawk. Would you recommend a router that is comparable to the Nighthawk? Especially one that has MAC cloning capability. And, as far as the cable modem goes, I guess any DOCSIS 3 would be fine?
TheEther wrote:A pure modem is a layer 2 networking device. It won't request an IP address from your ISP. Only your router will request an IP address, so MAC cloning will work.
