JohnCall
Apr 11, 2016Aspirant
Is Quality of Service (QoS) customizable on CM600?
Hi, I'm intersted in buying a new modem (CM600) that will allow me to prioritize my VoIP devices (a Polycom handset provided by my employer and a Verizon femtocell/network extender.) I've notice...
- Apr 28, 2016
Hello JohnCall
I have checked and there is no configuration on the CM600 for QoS settings and we will be checking with marketing to update the documents if require.
DarrenM
DarrenM
Apr 13, 2016Sr. NETGEAR Moderator
Hello Johncall
The CM600 is just a cable modem it does not have QOS settings on the device you would have to look at our Nighthawk routers for the Qos setting you can typically find screen shots for these settings in the user manual for the devices which you can find on our support page.
http://www.netgear.com/support/
DarrenM
