Golfman1007
Aug 04, 2016Aspirant
Limited or no connectivity
I recently installed a Netgear C3700 cable modem/router. I have a laptop running WIndows XP that I can't seem to get connected to the internet. I was able to connect with no problem on my older Netgear wireless router. I am not sure if my security settings need changed or what. Any advice?
Thanks, Mike
- DarrenMSr. NETGEAR Moderator
Hello Golfman1007
Did you name the SSID the same name as your old router if so you will need to go into your wireless settings on your PC and tell the PC to forget all networks with that name then try to connect again.
DarrenM
- Golfman1007Aspirant
The SSID is the name of the new router. I have other devices that connect without a problem. It is only my laptop that is running Windos XP.
- R0mpetotoAspirant
are you unable to connect to any website? can you login to your router?
I am connected to the wireless network but can not connect to any websites.
Hello Golfman1007
Are you maybe getting a ip address conflict you usually see a yellow triangle come up on top of your wireless connection icon.
DarrenM
