skiddles6969's avatar
skiddles6969
N600 Ports not communicating with PC
My router ports stopped workiing/communicating with my PC. I tried resetting the port, resetting cable modem, restarting PC, Inone worked. It still won't detect on PC, however, when I bypass router and hook up modem directly to PC there is an automatic connection made. Does anyone have any suggestions?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Skiddles6969
    Do you have another device that connects via ethernet that you can try and test it with?
    DarrenM
    • skiddles6969's avatar
      skiddles6969
      Hi Darren,
      Yes, I tested it with a laptop. I got the same error message. I reset the router, and still no communication with the PC or the laptop.
