Smile6's avatar
Smile6
Netgear c3700 slow speed
Hi:
I recently upgrade my internet service from 50 Mpbs to 200 Mpbs with TWC.   However, I can only get upto 51 Mpbs with both Wired and WIFI.
TWC did their test and sai every thing look goods on their end up to the modem.
Please help.
Thanks
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello SMile6
    If the cable connections all look good it may be that the Modem didn't provision properly and its still stuck on the 50 mbs connection I would contact TWC tier 3 tech support and have them look over there provisioning tools to make sure the modem is getting the correct boot file and its not stuck they should have you reboot it a couple times. Hope to hear your feedback.
    DarrenM
      • Smile6's avatar
        Smile6
        Thanks, yes TWC also informed me today of the 100 Mpbs limitation on this modem.  Right now I will be happy to get a stable connection with 100 Mpbs.
        TWC check and the provisioning/boot file are good.  Tech will be on site to check things out.
    • Smile6's avatar
      Smile6
      TWC Tier2 checked the boot file and everything look good.   We are scheduling an on-site tech to check it out.
      BTW.  I also noticed that since the speed upgrade, my internet connection is not as stable.  Maybe once a day I have to reset the modem to get my 50 Mpbs.
      Thanks
  • Having same issues since fri, 11/6. Twc recommended their own router, but I only bought this router last yr, hayyy... HELP!
    • nnr's avatar
      nnr
      Same here, I am also getting less than 1 MBps of download speed since 11/6. TWC checked and was able to verify that my download speed should be 60MBps. I brought mine 4 months ago, I am planning on getting a warrenty replacement.
      • DarrenM's avatar
        DarrenM
        Hello Everyone
        TWC was able to push out the old Firmware to everyone to fix the issue. Make sure you unplug your modem for a couple mins and back in see if this corrects the issue. If your still experiencing speed and packet loss issues let me know so we can get this corrected for you.
        DarrenM
  • my c3700 was only getting me 45mb on a 100mb thru Comcast/Xfinity (100mg wired confirmed) - dropped service to 50mb and was getting 26mb on wireless. now only getting 11.6mb.  Is there an upgrade (im missing) on this box or is it simply junk?
    • DarrenM's avatar
      DarrenM
      Hello JBurnz
      Are you getting these speeds on both the 2.4 and 5ghz? have you tried testing different wireless channels? Also do you have any old devices connecting to the network that use 802.11 b or g?
      DarrenM
