aerinater
May 03, 2017Aspirant
Netgear CMD31T blinking lights
My main question is what does it mean when both upstream/downstream pairs blink amber? I recently moved and changed services. About a week ago, my networking equipment was working perfectly. I've s...
- May 10, 2017
As a closing update to this issue, after having Spectrum technicians go through my setup, I learned that it might be that Spectrum has a specific set of coding that they use with their internet service that is different from Time Warner Cable (the two companies have merged, but many customers are technically still on Time Warner Cable's service) and my modem may no longer be compatible with their particular service.
Unfortunately I had to discontinue use of my purchased router and had to switch to one provided by Spectrum which does not incur a monthly fee like TWC did (for now).
Thank you for the responses.
DarrenM
May 05, 2017Sr. NETGEAR Moderator
It just indicates how many down and up stream channels are locked on if you are getting the speed you are paying for then nothing to worry about.
DarrenM
