Kakashi2000
May 16, 2019Star
next gen cablem modem ideas 2020
next gen cable modem ideas 2020
netgear is time for make gaming cable modem many years have been past and still the cable modem having problem with the performance and software fimware problem...
May 16, 2019Guru - Experienced User
Gaming and desires like that are kept to the router product line. Like the RAX and XR. If you want a good modem, the recommended mode is a stand alone only modem. Then connect a external router ot that modem.
One reason why having a combo modem like this would not be great, should the modem fail for any reason, you would loose the entire unit, when having a stand alone modem and external router, you wouldn't loose the router should something happen.
NetDumaOS will only be on XR series routers and NetDumas R1 router.
Broadcom would be best for chipset instead of Intel.
You should post this here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Good Luck and best wishes though.
