Bighac's avatar
Bighac
no voltage on POE port
Hello
I'm looking for some help and advice on working out how to use my Prosafe GS10TP I purchased it to run 3 unfi Wi-Fi discs they require PoE.
I cannot get the system to power the devices. I know the discs work because I have a single, stand-alone POE and if I connect it after going through the prosafe the disc works fine.
Thank you
Chris
  • > [...] my Prosafe GS10TP [...]
       GS110TP?  Not really a "Home Networking > Cable Modems & Routers"
    topic, is it?
    > [...] unfi Wi-Fi discs [...]
       UniFi?  Model?  Power requirements?  And then, what can the
    GS110TP(?) provide?
    • Bighac's avatar
      Bighac
      You tell me what should it come under?
      That was the only categories on the drop-down list
      • antinode's avatar
        antinode
        Guru
           Are we talking about a GS10TP or a GS110TP?
           Which "the drop-down list" was that?
           Knowing nothing, other than that it's not a router, I put "GS110TP"
        into the first "Search the Community..." box I found (at:
        https://community.netgear.com/t5/NETGEAR-Forum/ct-p/en-netgear), and was
        led to places like:
        https://community.netgear.com/t5/Managed-Switches/bd-p/business-managed-switches
           How was this determined?  Did you measure the voltage?
        > I cannot get the system to power the devices. [...]
           "I cannot" is not a useful problem description.  It does not say what
        you did.  It does not say what happened when you did it.
           From my brief reading, I gather that PoE is subject to control by the
        device administrator.  The "Smart Switch Software Administration Manual"
        has a section on "PoE Configuration", for example.
           Start at http://netgear.com/support/ , put in your model number,
        select Documentation, download the manual(s) of interest, and peruse?
        > GS110TP(?) provide?
           Still wondering.
