Czarnik
Oct 17, 2017Aspirant
Orbi & CG3000-2STATUS?
Can I use an Orbi with the CG3000V2 since it is the modem supplied by the cable coy?
If not Orbi, what other mesh netwowrk technology is compatible?
- DarrenMSr. NETGEAR Moderator
yes this should work just fine I would bridge the cg3000 make it a modem only.
DarrenM
- CzarnikAspirant
Yes, but that defeats the purpose of having the CG3000 wifi capable. So the Orbi & CG3000 WiFi networks don't work or don't work well together? Better to "mesh" with other Netgear extenders? If so, which ones?
