sirlancelot33's avatar
Dec 21, 2017
Parental control not working
Downloaded Netgear Genie.  Router is on and running (using it now), but when I try to eneble Parental Controls in Genie, it tells me "Internet is not available.  Connect your router to the Internet."  WTF?
  • Hi db4545,
    Welcome to the community!
    1. What is the firmware version of the router?
    2. Please try using another device (Android, iOS, computer).
    3. Have you tried resetting the router?
    4. Are you able to login through https://netgear.opendns.com/sign_in.php?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi sirlancelot33,
    2. Please try using another device (computer, Android, iOS).
    Dexter
    Community Team
    • sirlancelot33's avatar
      sirlancelot33
      Tutor
      Firmware has the latest version.  I don't have another device.  Of course I have reset and restarted the router.
      Anyone have any real solutions?
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi sirlancelot33,
      I have sent you a message. Please check your inbox.
      Dexter
      Community Team
      • db4545's avatar
        db4545
        Was there a solution? I'm having the same problem. Opening Parental Controls through the Genie program on Windows does not work. It either says I'm not connected to the internet (when I am), or the OpenDNS login fails (it's an existing account I have verified in my browser).
        R6700v3
