Drtyone's avatar
Drtyone
Follower
Sep 16, 2017
R7800 remote access with genie
How do I get the remote access to work when I am not on same network. I have he genie on iPad  and it works just fine locally but does not show up when off network
    • monsoon_qld's avatar
      monsoon_qld
      Tutor
      Finally got a chance to do as you suggested and it worked.  You wouldn’t have thought so though.  Genie (PC version) brought up all sorts of errors like password incorrect etc but somehow (miraculously) I now have RA to both D7800 & R9000 via iOS App. Thanks.
      monsoon_qld
      Tutor
      Admittedly haven’t done that. Uninstall Genie from PC as I’m a bit of a minimalist. I use Genie on iOS and access/setup D7800 via 192.168.1.1 I’ll give it a go but I haven’t had any issues with R9000 at home and no Genie on PC. D7800 is registered to myNetgear account.
  • Yeah I'm having the same problem.  Lost wifi altogether (but still had internet) when I upgraded firmware to .24 so downgraded to .22 and got wifi back but no RA.  Did all the usual, reset factory defaults, uninstalled genie on iPad and iPhone but no luck.  Curiously I can turn it on and off using 192.162.1.1 but no joy accessing it remotely.  I've tried having it off and turning it on using Genie no luck.  Tried the other around and still nothing.  Not having any RA problems with R9000 at different address.  Both NBN Fixed Wireless.
        monsoon_qld
        Tutor
        Yep I have. All my devices are listed. I have had RA working on it before, had a little difficultly with it a firmware update or so ago but this time it’s being much more stubborn. Just have to wait for another firmware update or Genie update. Will have a go at any other ideas that pop into my head in the meantime.
