Claire2708
Dec 28, 2017Aspirant
Compatibility between PLW1000v2 and XAV5501
Hi,
is it possible to connect to the Powerline AV+ 500 client adapters (XAV5001) to the PL1000 which is connected to my router? The PLW1000v2 kit was added to my network to create a Wlan access point in our cellar where my normal Wlan signal is not available. I am not sure if both systems are compatible. I was not able to get this configuration working.
Rgds
Claudia
Great, I managed to get the 500 plugs working :smileyvery-happy:
Thanks for all the help! I have also read the threads related to my specific topics and understand now much better how the Netgear adapters interoperate.
Happy new year and kind regards
Claudia
Claire2708 wrote:
Hi,
Yes. Just follow these instructions:
>>> Adding a powerline adapter to an existing powerline network <<<
It sounds like you have two separate Powerline networks, XAV5001 and PL1000.
You really need just one network. With the PL1000 connected to the router, add the other plugs one at a time. You can do this in the same room as the router to make it easier. Then move the new plugs to wherever you want them.
You face one issue with mixing 500 and 1000 plugs, the network will operate at the speed of the slowest plugs, the 500s. That probably doesn't matter for most applications.
The other difference between these two generations is that the 500s do LAN at 100 Mbps while the 1000s work at 1000Mbps. So use the faster plugs for devices with 1000 Mbps Ethernet, probably PCs.
- Claire2708Aspirant
Thanks. I assume that I have to reset the old 500 plug before I can reconfigure it to connect to the PL1000? As I configured the PLW1000 to take over the settings from my Fritzbox, I hope I do not loose any configuration made to my PLW1000 set.
I am wondering about all those different speed standards of the Netgear plugs. In case I would like to replace my old 500 plugs, which can/should I use? I found these, are they recommended: NETGEAR PLP1200-100PES PowerLAN-Adapter (1-Port, 1200Mbps)? E.g.
https://www.amazon.de/dp/B00WFV2QJ0/_encoding=UTF8?coliid=I1G5C6YD7EITJB&colid=U82QNQDM5YRG&psc=0
I assume that this a bundle where I can use both as new clients for my PL1000. What are the limitations for the 1200 plugs when using them at the PL1000?
Many thanks for any clarification on this!
You may not need to reset the plugs. Just following the instructions I linked to might be enough. I can't see that adding a plug will do anything to the PLW1000's settings. You won't be going anywhere near that plug.
You can add any plugs you like so long as they are AV compliant, which should cover anything sold now.
The 1200 plugs should be just fine. They also have 1000 Mbps Ethernet. The slightly different operating speeds is barely noticeable in comparison with the 500 to 1000 jump.
You don't even have to buy Netgear plugs, but I find it easier to stick to the same brand. Then you can use the same software to set up and control them.
