Retired_Member
Apr 11, 2023Error login into www.mywifiext.com.
Hi, I have a PowerLINE 1000 + WiFi (PLW1000).
I changed the password of my Access Point (128 characters long), with the possibility of recovering the password, by answering the two security questions.
I didn't change username, so it remained the same, i.e. 'admin'.
During the first login after the password change, an error similar to: 'Content Error text/html ... PWD:/usr/www' popped up.
I have looked references in my pc, not finding anything about folders or files.
Can anyone help me?
Thanks a lot!
to long of a password to log into it.
Maybe try factory resetting and doing a shorter 8-10 character password
- Retired_Member
Factory resetting is the last chance. If I can, I would like to resolve this problem not factory resetting.
tough to get in and access it if the password is the issue.
Password recovery just gives you the password but thats the problem.
