netcora
Sep 05, 2015Guide
XAV5001 Raspberry PI Raspian
Hello I have a Raspberry PI I want to connect with my XAV5001. And when I try to connect it gives me an IP of 169.xxx.xxx.xxx range when I give ifconifg command and is supposed to give me an IP in range of 192.xxx.xxx.xxx. Now I hve so many devices and all work fine with the XAV5001 all acquire IP´s on range of 192.xxx.xxx.xxx and run perfects but the Raspberry PI with Raspbian OS shows the 169.xxx.xxx.xxx and is not connecting at all.
Anyone know what could be the problem of why I´m acquiring the 169.xxx.xxx.xxx range and not internet connection?
Thank you
- JamesGLNETGEAR Employee Retired
Hi netcora,
Welcome to Community!
Does your Raspberry Pi works on a different wireless network? If you have an option to set an IP address manually on your Raspberry PI, then you can try to use same range as with the main router that provides DHCP.
JamesGL
Community Team
- netcoraGuide
Look the raspberry PI wireless is not connected because is an openvpn access point. The Ethernet IP is the problem. I configured also on interfaces configuration of Raspbian like dhcp and nothing. And on my router I tried via macid force to have an IP and nothing still giving an IP of 169.xxx.xxx.xxx. Suppose there is no wireless connections and what I want is to have internet via de powerline and the Ethernet only.
Thank you. What could be the problem?
