Wallou's avatar
Wallou
A6210 no AC connection , only N
Hi,
My A6210 does not connect to my router in AC mode.
Only in N.
I am on Windows 10 x64.
I notice it now because i just got a 1Gb fiber connection and the bandwich is not as it should be.
This occurs only with A6210 because friends on their laptops connect in AC with the built-in wifi chip.
I tried to install latest firmware/softawre but nothing changes.
Here is a screenshot of the task manager :
Please advice.
Thanks
  • It could be a bug in the Task Manager.  Go to Network and Sharing Control Panel and click on the blue link for your Wi-Fi network.  IIRC, this will display the connection status and, possibly, the protocol.  If you are running Windows 10, then I believe the protocol is also displayed in Settings->Wi-Fi, somewhere.
    If you find that the adapter is truly using only N, then go to the driver settings and see if there are any options to use AC.
    • Wallou's avatar
      Wallou
      Hi
      Sorry for late reply i have been on holidays for 3 weeks and be back in a few days at home.
      Wherever in Windows I look it's a N WiFi connection I have.
      I don't recall seeing such a parameter in the driver settings.
      I have an Asus RT-AC68U router and as stated above friends get AC connection so the router is fine I think.
      I am pretty sure I am in N connection because friends have way better bandwidth speed compared to what i have with my Netgear A6210.
      I made tests from the same room in my house and good WiFi signal.
  • What is your router? Is it set up to use -ac mode on wireless?
    • dk2463123's avatar
      dk2463123
      I think OP has already stated that others connect as -ac so it sounds like the network is correctly set to handle the -ac protocol. This sounds like the already known and still unaddressed issue where the A6210 reports back as -n on Windows 10 even when connected to an -ac network. There is supposedly an alpha software patch floating around but this issue seems to be known already by Netgear but not resolved.
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi  All,
        Please PM me your contact info if you have issues showing incorrect mode even when connected to an AC router
        JamesGL
        Community Team
  • Retired_Member's avatar
    Retired_Member
    I have the same issue and I would like the download to the patched version of the driver. Even if it is a PreTest version.
    • Wallou's avatar
      Wallou
      I come back here to give a few feedbacks after some tests i have made.
      Despite seeing 802.11n in task manager , i think my a6210 is in fact connected in AC mode as i can see in the wifi network details that i am connected at 866mbits to my asus router.
      But there is one thing i don't understand is why i can't go faster than 300mbits when testing my connection speed with online tools.
      I read that it could be related to my a6210 running in usb2, but it is not the case.
      With usbtreeviewer i see it is connected to a usb3 port.
      When i connect through ethernet to my router i get speed tests above 700mbits, i have a 1Gb fiber connection.
      I would expect to have better speed in wifi with the a6210.
      But still i find it disturbing as 300mbits is the 802.11n max speed rate.
      Anyone can help me to go faster than 300mbit please ?
  • TL;DR 300 Mbps is pretty normal out of a 867 Mbps Wi-Fi connection.
    Unlike Ethernet, Wi-Fi link speed (the connection rate reported by Windows) and throughput (the real world, actual speed) are very different. The reason is that Wi-Fi requires a lot of overhead. A rule of thumb is to expect throughput no better than 50% of the link speed. It will frequently be worse than that. 300 is 34% of 867, which is pretty typical.
    While Wi-Fi is great and convenient, if you want the best, most reliable performance, use Ethernet.
