Schyler
May 18, 2015Aspirant
Losing Packets
I have the A6210 WIFI adapter and I am experiencing packet loss. This just started. I have tried updating and everything but it just lags to hell. Please help!
- fordemMentorFirst - packet loss between where & where? Second - have you considered the possibility of interference (RFI) from adjacent networks, microwave ovens, etc., etc.?
- SchylerAspirant
fordem wrote: First - packet loss between where & where?
Packet loss just playing any online game such as BF4. I get the packet loss symbol and get extreme rubberbanding. I also did ping 10.0.0.1 -t which is my gateway and I get request timeout for every like 30 successful attempts. I just started having this problem and nothing has changed in my setup. - fordemMentorSo for all you know the packet loss could be occurring between your ISP and their ISP - which would be totally outside of your control and not indicative of a problem in your network.
- dug_lessTutorFire up command prompt and ping path google. See if you are finding packet loss/time outs along the path.
- fordemMentorThat would be "pathping".
- SchylerAspirant
dug_less wrote: Fire up command prompt and ping path google. See if you are finding packet loss/time outs along the path.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\XXXX>ping google.com -t
Pinging google.com [2607:f8b0:4006:80a::1002] with 32 bytes of data:
Reply from 2607:f8b0:4006:80a::1002: time=22ms
Reply from 2607:f8b0:4006:80a::1002: time=25ms
Request timed out.
Reply from 2607:f8b0:4006:80a::1002: time=646ms
Reply from 2607:f8b0:4006:80a::1002: time=30ms
Reply from 2607:f8b0:4006:80a::1002: time=27ms
Reply from 2607:f8b0:4006:80a::1002: time=29ms
Ping statistics for 2607:f8b0:4006:80a::1002:
Packets: Sent = 9, Received = 8, Lost = 1 (11% loss),
Approximate round trip times in milli-seconds:
Minimum = 22ms, Maximum = 646ms, Average = 102ms - FairytailVirtuosoCan you try to Ping as well your router and see if it has packet loss. Do you get the same problem using a different device?
- SchylerAspirant
minions08 wrote: Can you try to Ping as well your router and see if it has packet loss. Do you get the same problem using a different device?
Yeah I had the same exact problem.
C:\Users\asus>ping 10.0.0.1 -t
Pinging 10.0.0.1 with 32 bytes of data:
Reply from 10.0.0.1: bytes=32 time=1115ms TTL=64
Reply from 10.0.0.1: bytes=32 time=11ms TTL=64
Reply from 10.0.0.1: bytes=32 time=5ms TTL=64
Reply from 10.0.0.1: bytes=32 time=1ms TTL=64
Reply from 10.0.0.1: bytes=32 time<1ms TTL=64
Request timed out.
Reply from 10.0.0.1: bytes=32 time=1622ms TTL=64
Ping statistics for 10.0.0.1:
Packets: Sent = 16, Received = 15, Lost = 1 (6% loss),
Minimum = 0ms, Maximum = 1622ms, Average = 184ms
Control-C - NomakeWanAspirantI'm not sure if this will help, but have you tried the Mediatek USB driver from Mediatek's website rather than using Netgear's drivers?
- malratsAspirantI'm having the exact same issue with the A6210, except I just bought it yesterday to try to replace my malfunctioning A6200 (can't connect to 5GHz channels in the 3-digit range).
I was playing Final Fantasy XIV last night and kept getting intense lag spikes. I switched back to the A6200 and connected to the 2.4GHz network (since that's all available to me) and there was no issue at all.
Today I pinged google and my router both with the A6210 using both the latest Netgear driver and then the latest Mediatek driver. Both consistently resulted in an average of 15% packet loss.
I immediately ran the same tests with the A6200 and consistently had 0% packet loss.
Something is clearly going on, and I don't know if it's defective and I should get another unit or if it's just always going to do this.
