Dickie543
May 23, 2017Aspirant
Netgear AC1200 USB WiFi Adaptor
Can I move the AC1200 WiFi USB adapter between two computers until I get to a store and buy a second WiFi adapter? It is an hour drive one way, I work in the other direction, and there is just no time right now. My husband wants internet access TONIGHT and he gets too frustrated doing computer stuff himself. If I can, do I install it with the CD that came with it? And if so, will I have to install it again when I purchase a new WiFi adapter as long as it is the same model? If it is a different model, will it still work, or will I have to install with the new CD and WiFi adapter? (when I bought this adapter, it was the last one in stock, but it works great)
Hi Dickie543,
You can install the adapter on a different computer. You can visit support site for the driver.
https://www.netgear.com/support/product/A6210.aspx#download
If you purchase the same model, no need to reinstall the driver.
- JamesGLNETGEAR Employee Retired
Hi Dickie543,
