Hxllxws's avatar
Hxllxws
Follower
Mar 23, 2016
Netgear n300 usb adapter doesnt work..
So i recently built a computer and i know everything works fine. Ask for specs if you need them but anyway whats important is this adapter. This is my second one. Both have done the same thing to me. The first one stopped being recognized so i thought it was my computer and after ruining the corrupted driver more it wasnt detected at all... So i decided to restart my computer completley with windows 7. After that the computer still couldnt recognize the usb adapter even after installing the software. I followed all the installation steps perfectly. So i even called the netgear help desk to trouble shoot and nothinf worked so i have gotten this replacement today and it worked awesomely like the first one did... But then my computer froze i guess and when i restarted i wasnt connecting tonthe internet. Just like the first one. Except my computer still recognizes this usb adapter it just wont download the driver or what wver and the stupid genie wont open either.. Why wont anything work???? Can someone help me? Ive turned off avg completely as well as my fire wall and my wlan thing is on automatic and is started. What can i do?
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Hxllxwas,
    Uninstall the driver of the adapter. Once done uninstalling, reinstall using the standalone driver and not the drive with genie.
  • JamesGL's avatar
    JamesGL
    Hi Hxllxwas,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    • AdapterHelp's avatar
      AdapterHelp
      I am aslo experiencing the same issue. Could this be related to a bad update?
      • JamesGL's avatar
        JamesGL
        Hi All,
        Have you tried my suggestions on my previous post? If not yet, please try it and also try to install it on a different computer.
  • WNA3100M driver will not install on my win 10 x64 pc. It hangs with 0%cpu usage.
    • JamesGL's avatar
      JamesGL
      Hi nicho1981,
