KTSong
Feb 28, 2017Aspirant
Netgear WNDA4100 N900 Frequently Disconnects
Hello,
I have Window 8.1. I use The Netgear WNDA4100 N900 Adapter. It frequently disconnects and looses its signal. All other wifi devices in the house run well. My computer is the only one that cannot stay on the internet. Is there any help that can be given for this? I am very frustrated. I am constantly removing the plug from the USB port and plugging it back in, to connect to the signal. I have used multiple USB ports and the same issue happens.
Thank you for your time.
- KTSongAspirantSorry. I am having trouble getting my connection to load the page. I am answering you from my phone (that's how bad it is). I'm not sure how to get this update now...
Sure when you are avalable fire up!
- KTSongAspirant
OK. I tried it. It did not work. Still disconnecting from the internet...
- KTSongAspirantThanks. Are you able to supply me the link to the newest driver, please?
http://downloadcenter.netgear.com/#searchResults
type WNDA4100 and select win 8.I can't send you the file sorry:(!
Is it working?
Keep me in the loop!
- KTSongAspirantSorry for the late reply. The driver version I have says 5.1.19.0
Driver date is 10/1/2014Try the most recent driver and see what happen usually it is working!
Do you have the Negear FW for your device?
it can solve the issue.
Keep me posted!
- KTSongAspirant
Hello,
What is "The Netgear FW"?
FW Firmware.
What is the version of the driver you use or not to connect the device to Win 8?
