denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys,
Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this?
thanks in advance
- WirelessWackoAspirantJust did a fresh install with Windows 7 x64 after having some problems with windows 8, Everything seemed to be working fine until the first reboot for drivers.
I have to disable the A6200 through windows, or disconnect the adapter manually. It always seems to work after the first try.... - Mark_KTutorI am having the same issue.
After the upgrade I am have an issue where after boot up my a6200 will not connect to my R6300 until I unplug the adaptor and plug it back in. - emondragonNoviceI too was having the same problem. I discovered when I upgraded from .18 to .26 firmware the problem of not starting up again began. My setup is HP TouchSmart 600 using Windows 7 64bit computer. I uninstalled the .23 firmware and installed again the .18 firmware and problem was solved. I'm afraid to use the firmware updates.
- AdohlNoviceWhen I was running windows 7, there was no problems at all. But since installing windows 8 recently, I've had nothing but trouble.
- Dacow79Aspirant
denny1514 wrote: Hi Guys,
thanks in advance
I have the same issue. Are you running Windows 7 x64? - cilonieAspirantHi denny1514,
Have you tried connecting the wireless adapter on other USB slot?
Is the wireless adapter directly connected to your computer or you are using the Desktop Dock?
What is the operating system of your computer?
You may try to install the wireless adapter to a different computer and check if you will encounter the same problem.
