Handstand
Apr 15, 2018Aspirant
WNA 3100 Adapter Windows 10 Pro Failure
I understand that there is an issue with detecting the USB adapter when on Windows 10 during the installation which has been solved.
I just finished building my PC and currently using Windows 10 Pro. I’ve tried tutorials to fix it but I can’t follow all the steps that are shown as they’re using the regular windows 10.
Please help.
Please help.
I assume that you have tried the latest software for your device:
WNA3100 (N300) Wireless USB Adapter Support | NETGEAR
Some people find that they do not need any software or drivers. They just use the stuff that comes in Windows 10.
- HandstandAspirantI can’t download that as I don’t have WiFi on my PC and only limited to the CD I was given.
You have access to the internet, or you would not be here.
Have you tried to download the file to whatever you use to get here? Then put it on a USB drive and load from that.
