explorer12's avatar
explorer12
Initiate
Apr 04, 2017
Change to different wifi source
I want to set up my Netgear EX6200 with a different wifi source.  I am using it on a boat and move around quite a bit.  I wish to be able to use different wifi in various marinas.  I tried to do a factory reset by pushing the interior button with a paper clip for seven seconds.  However it still shows the old  2.4 and 5 mhz output channels.  I cannot find a way in to designate a new wifi internet source to rebroadcast using this range extender.  does it have the capacity to search for available wifi and enter a password?  Will I have to re-enter the information if I return to a wifi that I have used in the past or will it retain more than one wifi network with it's unique password?
  • Hello explorer12
    You have to factory reset the unit  for every new router you want to connect the unit to make sure you hold the reset button for 10 + seconds.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello explorer12
    DarrenM
    • explorer12's avatar
      explorer12
      Initiate
      When I follow the instsructions, puch in the reset pin in the back and hold for seven seconds, it does not seem to do a true factory reset.  When I sign in to the repeater, the old named 2.4 and 5 mhz networks are still showing.  By all rights with a factory reset, they should not be present any longer.
      Any tips to assure a complete factory reset?
      • TheEther's avatar
        TheEther
        Guru
        Log into the EX6200, go to Settings > Other and select the Reset option.
  • Hi. I have a wn1000rp and have changed broadband suppliers. I can't reset and as i can't logon to the genie app without connecting to the extender i am stumped. Can you help?
