CCBaxter
May 21, 2017Aspirant
Half speed even with Fastlane?
Hi. I have a 6150v2 range extender, configured to use Fastlane. It connects with my router using 2.4GHz (wireless N) and with my devices using 5GHz (wireless AC).
When I'm connected directly to the router, without the extender, I get around 85mbps, so I was hoping I could get almost the same speed using the extender, but nowhere near that. When using the extender the max speed is around 35mbps, around half the speed I was hoping.
I understand usual extenders work this way, reducing the speed to half, because they receive and send data using the same frequency, but I thought using Fastlane that wouldn't be a problem. Is this how it should be working? Is everyone getting half the speed even when using Fastlane?
- DarrenMSr. NETGEAR Moderator
Hello CCBaxter
Have you tried to change the wireless channel to see if you get a faster connection?
DarrenM
- CCBaxterAspirant
Hi, thanks for the reply.
Haven't tried that yet, will try it later today.
About Fastlane, do you use it? Do you have the same speed as when connected directly to the main router?
- netwrksMaster
Using an extender will give you a 50% loss in throughput. So, 35Mbps, is about right.
EDIT: your extender supports AP mode, you should strive to set it up in AP mode.
- CCBaxterAspirant
Tried changing channels, I get the same results.
Phone directly connected to the router - 80Mbps
Phone connected to extender - 35Mbps
This isn't bad at all, and 35Mbps is enough for the streaming I do in the room that had poor wifi.
I'm just wondering if anyone here knows exactly what are the benefits of using FastLane and clarify if people should expect better speed when using it, or the usual 50% loss that's common in range extenders.
- GeochronInitiate
Hey! Yes same thing here in either fast lane mode speed is halved, so that's router to extender in either but not both 2.4 or 5 ghz and then router to device on the opposite.
What's interesting though is that simply leaving the default with fast lane off and broadcasting both frequencies from the extender I get nearly the full connection speed.
Ill be leaving my extender in the default without fast lane as it's twice as fast for me. Interested to hear if others see the same.
- CCBaxterAspirant
Hi Geochron, thanks for the reply.
I just tried turning off fastlane and using "basic mode", but the results are basically the same. Maximum speed is about half of when connected directly to the router. Curious that it's twice as fast for you, I wonder if anyone else is getting faster connections with fastlane off.
My results:
Phone connected to extender with fastlane ON- 35Mbps
Phone connected to extender with fastlane OFF (Basic Mode)- 35Mbps
- exxtreme76401AspirantNote that distance and obstructions from the extender plays a great deal into how fast the connection speed is. My Netgear ex7300 can do 1300 mb/s but realistically does more like 866 across the room. That real world speeds of ~170 MB
