kky29's avatar
kky29
WiFi Extender Ex6200 AC1200
I have this AC1200 Netgear wifi extender Model EX6200 for quite some time. It has always been a problem in continuous connecting to the 5G EXT network. Every few hours our iphone connection drops from 5GEXT network and goes to the other normal wifi without extender. I have 3 iphone in the family and it happens with all of us. After few hours, we have to go to device setting and search and conenct to 5GEXT. It works for few hours and goes back again to normal wifi router without extender. I have tried rebooting, updating sfotwared, restarting iphones,laptops, etc. But no luck. Would anybody have some suggestion for this problem.
Thanks,
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello kky29
    Have you checked if some feature in the device is telling the device to switch to a stronger signal the extender network may become weaker for a minute then the device switches to the main network.
    DarrenM
    • kky29's avatar
      kky29
      Thanks Darren for the response. It is possible that this is the reason. How can I know about it for sure? Is there any way that the connected network does not change from 5GEXT option at home. I have another wifi modem. How do I make sure that my iPhones do not connect to anything other than 5GEXT option at home.
      Thanks
      • kky29's avatar
        kky29
        Thanks
