fixitman
Aug 07, 2016Aspirant
WN3000RP signal ext
I have the WN3000RP signal extender, that is extending my signal from my main router, which is a Cisco Linksys EA3500. However I have a older Netgear router which is a WGR614v10. I cannot seem to get...
DarrenM
Aug 10, 2016Sr. NETGEAR Moderator
Hello fixitman
You would want to disable the DHCP server on the WGR614v10 in the LAN settings since it will behind you main router. But you may just want to pick up a switch to hook up to the extender if you are just looking to have more Ethernet ports in another location.
DarrenM
fixitman
Aug 15, 2016Aspirant
Yes I will disable the DHCP. However this is what i am needing to do. My main router is in the heart of my house, and I have some detached buildings that i would like to have WIFI access.
Main router : Cisco Linksys EA3500
extra router : Netgear WGR614v10
extender : WN3000RP
So i have been trying to connect the Cisco and Netgear together, but to no avail. So i thought I could extend the signal from teh main router and then since the extender and extra router are the same brand name I thought I could connect them and have the WIFI access to my buildings.
Any suggestions.
Thank you in advance and I am sorry to be a bother.
- DarrenMAug 18, 2016Sr. NETGEAR Moderator
Hello fixitman
I would make sure your main routers Security is WPA2 and maybe try changing the channels then factory reset the extender and then try to connect it to your Linksys router.
DarrenM
