RSchwein
Mar 21, 2011Aspirant
WNDAP350's are constantly rebooting
WNDAP350 significant problems
I have 5 of these on various network segments over a large geographical area. All are using different wiring, different network switches, nothing in common with any of them except one thing. All are experiencing exactly the same problem.
Log excerpt
Mar 21 11:41:51 hostapd: Network Integrality: Ping Failed
Mar 21 11:41:51 hostapd: Network Integrality: Host: 10.110.255.254 is down.Bringing down all the vaps
Mar 21 11:41:51 kernel: brtrunk: port 2(wifi0vap0) entering disabled state
Mar 21 11:41:51 hostapd: wifi0vap0: STA 00:1b:63:cc:f5:40 IEEE 802.11: disassociated
Mar 21 11:41:51 hostapd: wifi0vap0: STA 00:26:4a:c1:51:26 IEEE 802.11: disassociated
Here is what I've learned:
When there are no associations at all (over a weekend for example) there are no problems; pings are always successful.
After there are a couple (two or so) associations then the above occurs maybe about once every 4 hours. You start getting more associations then the “Ping Failed” occurs more frequently. On one where there are about 30 associations the failure occurs about every 20 minutes, sometimes more frequently.
I am aware that these 350s ping their respective default gateways. Examination of the router's respective logs show the routers are working flawlessly. Indeed, everyone “wired” on the various network segments are not having any problems. Each 350 has it's own Gig/sec connection. Measured network traffic is rarely over 3% of available capacity.
So, in the 350's firmware, is it waiting a shorter and shorter amount of time for a ping return as the number of associations increase? Therefore, it is timing out waiting for the return when if it would wait just a little longer it would be satisfied?
I've got to solve this problem before I can deploy anymore 350s. I'm not replacing anymore WAP54G's which are working just fine.
Thanks for any help here.
Bob
Log excerpt
Bob
- overlookTutoryes it can be ...
Here when rogue was set to on users were still complaining about erratic wifi performance and drop-offs !
When rogue is on the AP scan your network continuously to find another unwanted (or not) APs. When set to off, connections work flawlessly ;)
For the 350 system log i have found why there is nothing here ! We have configured APs to use a syslog server. If i disable the syslog feature all logs are showing in the system log window ! Humm Netgear support : :mad: Netgear never told me that...
But, if you can, use a syslog server (kiwi or another soft of your choice) rather than the Ap buffer; there is no log size limit, you can archive, email, etc....
Since 1 year we have these APs all logs are archived. I have searched for "entering disabled state" keywords and i have only found that each time it was disabled state it was for technical reason and not an issue.
Try with rogue set to off and tell us if it's (better) work or not :D - GlithAspirantTry and disable DFS on the 5Ghz radio....
I found a bug where the DFS got stuck in a loop and disabled all network traffic. - overlookTutorour ping test results : 2,4 and 5ghz are always UP for all APs ;)
- RSchweinAspirant
Glith wrote: Try and disable DFS on the 5Ghz radio....
Cisco's are still working fine.
Linksys's are still working fine.
Apple Airport still working fine.
Netgear 350's still turning off their radios. For an experiment I put two 350's onto the same network segment about 100' apart with low power settings and different channels. Of course both were pinging the same router. I watched them for a while. After about an hour one had a ping failure and disconnected. But the other was doing just fine. After about a minute it came back up. A little while later the second had a ping failure and disconnected. However the first was still fine. Everything I've done seems to point conclusively to something in the 350 having problems.
I've just turned off all the 5 Ghtz radios. We'll see. - overlookTutorFaulty hardware series :confused:
To be sure call your Netgear tech support and ask for a RMA for 1 AP and test.
;) - RSchweinAspirant
overlook237 wrote: Faulty hardware series :confused:
Now that I know where to look I've been packet capturing with a focus. Comparing what I capture with the 350's logs shows that the 350 and reality are not collocated.
When the 350 goes off line it's logs show that it is pinging and not getting a reply. However, packet capture shows that all pinging stops. Indeed, during the 350's blackout someone on the network can not ping the 350. It appears to have turned off its Ethernet port. Yet, it's log shows that it believes it is connected to the network and it continues to ping.
Firmware; Hardware? I haven't called Netgear yet; would I be the first to surface this problem? - GlithAspirantTry to disable Auto channel if you have it set on any radio.
- RSchweinAspirant
Glith wrote: Try to disable Auto channel if you have it set on any radio.
They are all set to Auto channel. Heck, I've pretty much disabled everything else, why not this? I'll try it.
In the mean time - below is the relevant part of the 350's log:(everything fine)
Mar 28 14:21:56 hostapd: Network Integrality: Ping Success
Mar 28 14:22:50 hostapd: Network Integrality: Ping Failed
Mar 28 14:22:50 hostapd: Network Integrality: Host: 10.100.255.254 is down.Bringing down all the vaps
Mar 28 14:22:50 kernel: brtrunk: port 2(wifi0vap0) entering disabled state
Mar 28 14:22:50 hostapd: wifi0vap0: STA 00:1f:f3:bd:f6:c3 IEEE 802.11: disassociated
Mar 28 14:22:50 hostapd: wifi0vap0: STA 00:16:ea:c3:44:b2 IEEE 802.11: disassociated(kicks everyone off)
Mar 28 14:22:58 hostapd: Network Integrality: Ping Failed
Mar 28 14:23:01 hostapd: Network Integrality: Ping Failed
Mar 28 14:23:01 hostapd: Network Integrality: Host: 10.100.255.254 is down.Bringing down all the vaps
Mar 28 14:23:06 hostapd: Network Integrality: Ping Failed
Mar 28 14:23:09 hostapd: Network Integrality: Ping Failed
Mar 28 14:23:14 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:04 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:08 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:11 kernel: NETDEV WATCHDOG: eth0: transmit timed out
Mar 28 14:35:11 kernel: ag7100_tx_timeout
Mar 28 14:35:11 kernel: ag7100_ring_free Freeing at 0x803ec000
Mar 28 14:35:11 kernel: ag7100_ring_free Freeing at 0x86a6c000
Mar 28 14:35:11 kernel: ag7100_ring_alloc Allocated 4800 at 0x803ec000
Mar 28 14:35:11 kernel: ag7100_ring_alloc Allocated 3024 at 0x86a6c000
Mar 28 14:35:11 kernel: AG7100: cfg1 0xf cfg2 0x7215
Mar 28 14:35:11 kernel: VSC8601: Found 0 unit 0:0 phy_addr: 1 id: 004dd04e
Mar 28 14:35:11 kernel: VSC8601: PHY is an Atheros F1E
Mar 28 14:35:11 kernel: VSC8601: unit 0 phy_addr 1
Mar 28 14:35:11 kernel: Writing 4
Mar 28 14:35:11 kernel: brtrunk: port 1(eth0) entering disabled state
Mar 28 14:35:12 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:15 kernel: VSC8601: unit 0 phy_addr 1
Mar 28 14:35:15 kernel: AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
Mar 28 14:35:15 kernel: AG7100: pll reg 0x18050010: 0x11110000 AG7100: cfg_1: 0x1ff0000
Mar 28 14:35:15 kernel: AG7100: cfg_2: 0x3ff
Mar 28 14:35:15 kernel: AG7100: cfg_3: 0x18001ff
Mar 28 14:35:15 kernel: AG7100: cfg_4: 0xffff
Mar 28 14:35:15 kernel: AG7100: cfg_5: 0xfffef
Mar 28 14:35:15 kernel: AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
Mar 28 14:35:15 kernel: brtrunk: port 1(eth0) entering learning state
Mar 28 14:35:16 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:20 kernel: brtrunk: topology change detected, propagating
Mar 28 14:35:20 kernel: brtrunk: port 1(eth0) entering forwarding state
Mar 28 14:35:20 hostapd: Network Integrality: Ping Failed
Mar 28 14:35:21 hostapd: Network Integrality: Ping Success
Mar 28 14:35:21 hostapd: Network Integrality: Host: 10.100.255.254 is UP. Bringing up all the vaps
Mar 28 14:35:21 kernel: brtrunk: port 2(wifi0vap0) entering learning state
Mar 28 14:35:25 hostapd: Network Integrality: Ping Success
Mar 28 14:35:25 hostapd: Network Integrality: Host: 10.100.255.254 is UP. Bringing up all the vaps
Mar 28 14:35:26 kernel: brtrunk: topology change detected, propagating
Mar 28 14:35:26 kernel: brtrunk: port 2(wifi0vap0) entering forwarding state
Mar 28 14:35:32 hostapd: wifi0vap0: STA 60:fb:42:6d:6d:3e IEEE 802.11: associated
Mar 28 14:35:43 hostapd: wifi0vap0: STA 00:1f:f3:bd:f6:c3 IEEE 802.11: associated - RSchweinAspirantNote that the 350 was down for over 10 minutes (between 14:23 and 14:35). All the while it was pinging away about every 4 seconds even though it had disabled it's own Ethernet port!
- bserratoAspirantI'd like to know if you were able to resolve this. I'm having similar problems except I'm finding the log is not actively updating itself. I did see that at some point in the past the AP put all wireless connections into promiscuous mode then eth0 into promiscuous mode. I'm only using the 5GHz radio and switched from 40MHz to 20MHz today, but the painful pauses in connectivity continue.
Might any of you have any suggestions?
