pbackstrom's avatar
pbackstrom
In loop trying to log on
When I try to log on, either with a one-time password or with my password, it says
“Your router is registered to [my email, the same one as I’m trying to get on with]. Login using this account and try again.
Thus I’m in a loop.  Suggestions?
[the TP-Link in the previous post was an error, sorry.  It's R6400v2.]
  • Log on where?
    Where is a one-time password used? I've never heard that for an NG router.
    • pbackstrom's avatar
      pbackstrom
      Hmm, can't replicate.  Email is below.  I did try resetting my password as well.
      The main problem is  I'm in Nighthawk, it shows a graph of my router plus Device Manager, Security, Internet Speed etc.  I click Security and it takes me to the sign on screen that I keep looping back to.  I push "Sign In," then "Sign into existing account,"  put my email and password in, and I'm back to the looping screen.
      • microchip8's avatar
        microchip8
        Master
        So you're in the app and try to access Security? Which, if I recall, is about Armor/Bitdefender?
      pbackstrom
      I got on directly so this is resolved.  Here's the OTP screen for your information.  Thanks.
  • Here's the screen I keep getting
