Prokur
Sep 22, 2016Follower
R6300v2 and Facebook Wi-Fi
Dear community, I just have bought Netgear R6300v2 to use it in my bar with Facebook Wi-Fi function. The latest available firmware V1.0.4.6_10.0.76 is installed, Guest access is enabled, but every t...
Retired_Member
Sep 23, 2016- pcebavaroNov 01, 2016Aspirant
Hi folks,
I have exactly the same issue, facebook wifi option totally stuns the netgear r6300v2 router. After clicking on configure button a new tab is opened - https://www.facebook.com/wifiauth/config?gw_id= - and the router GUI becomes unresponsive (only if I unplug and plug back the AC adapter I can enter the GUI again). I have the latest firmware (V1.04.6_10.0.76) and latest Netgear Genie (V2.4.34) which btw is totally useless for facebook wifi feature simply because there is no such option anywhere in Netgear Genie app (only basic router settings there). I've also noticed that if using Chrome or any chromium browser (Comodo, Torch etc ...) for GUI, the facebook wifi button is not visible because its hidden behind the help bar in lower part of the window (I actually made it by using the tab button on keyboard to select that option and hit enter - of course the poor router got stunned again even from chrome after hitting the configure button). GUI works fine from Firefox and IE but still the only thing that configure button for facebook wifi can do is to stun the GUI (router itself still works, internet connection is OK but the GUI becomes unresponsive, even with closing the page and trying from other browsers I can't login to router anymore unless I unplug the AC and plug back in). I've searched and searched for the solution but nada, and I'm really good in searching for solutions ...
I think its a bug in the firmware but I wont downgrade it cos I've already lost too much time with this toy router, hope that Netgear will fix this issue soon.
- DexterJBNov 03, 2016NETGEAR Moderator
Hi pcebavaro,
1. Does the issue persist when using other device/s (another computer, mobile device)?
2. Have you tried doing a factory reset?
3. Have you tried re-flashing the latest firmware?
Dexter
Community Team
- adusonuDec 21, 2016Aspirant
Hi Dexter,
I am also directed to a "page not found" error on the following link: https://www.facebook.com/wifiauth/config?gw_id=
My firmware is
V1.0.4.6_10.0.76Any help appreciated.
- sameer79Aug 11, 2017Aspirant
Hello Dexter,
Same problem with my router as well. It rediredirecting me to this page "https://www.facebook.com/wifiauth/config?gw_id=" which shows this page is broken. The GUI is not responding soon after this page opens.
One more thing is that it shows a router firmgrade is available but when tring to install it after the download it shows an error
- DexterJBNov 06, 2016NETGEAR Moderator
Hi pcebavaro,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- momocha_86Nov 11, 2016Aspirant
Hi,
I also having similar issue here. When i click "Configure" under "Adcanced Setup --> Facebook WIfi", it will link to https://www.facebook.com/wifiauth/config?gw_id= but the page is not available (with message below). Tried on IE and Google Chrome. Can you please help?
Firmware version: V1.0.4.6_10.0.76
Sorry, this page isn't available The link you followed may be broken, or the page may have been removed.
