Prokur
Sep 22, 2016Follower
R6300v2 and Facebook Wi-Fi
Dear community, I just have bought Netgear R6300v2 to use it in my bar with Facebook Wi-Fi function. The latest available firmware V1.0.4.6_10.0.76 is installed, Guest access is enabled, but every t...
xuandna
Mar 10, 2017Guide
Omg,
Same problem with me here ! I had old NightHak R8000 which not support FB wifi, i did bought one R6300v2 on amazon but today i configure FB wifi then stuck at link: https://www.facebook.com/wifiauth/config?gw_id=
I need to Unplug to restart the router .... but same problem happened.
Please help !
pugwash1971
Mar 10, 2017Tutor
I downloaded the latest firmware and it didnt work. I then downloaded the previous version and the Facebook wifi link did work and I was able to set it up.
It worked on my phone when I tried it, but when my customer did the same, he got a different response. My phone is Android, his phone is Apple.
In any case whether you get it to work or not, its a waste of time because users can "skip check-in" which totally defeats the reason for having the option.
The way the product is marketed says that users "check-in and like your page before getting free wifi". This is incorrect and false advertising.
You can hit the business Facebook page and "skip check-in" and still get free wifi. So whats the point ??
I dont have enough money to take on Netgear in court over false and mis-leading advertising but if I did, I would.
In fact I have less money now from when I started on this project as I have purchased the router but my customer, quite rightly, wont pay me for it as it doesnt do as it was supposed to do.
- mariusmeMar 11, 2017Aspirant
Dear Sir,
Other routers listed on the facebook page are also acting the same way, I've tried a couple of models now, so the customer (coffe shop ...) should know that not all customers will share location or like their page.
thank you
