Prokur
Sep 22, 2016Follower
R6300v2 and Facebook Wi-Fi
Dear community, I just have bought Netgear R6300v2 to use it in my bar with Facebook Wi-Fi function. The latest available firmware V1.0.4.6_10.0.76 is installed, Guest access is enabled, but every t...
xuandna
Mar 10, 2017Guide
hi pugwash1971,
After logged in ... at the Facebook wifi configuration there have an option to enter your private key if user skip check-in
Btw, for problem stuck at https://www.facebook.com/wifiauth/config?gw_id=
I figured out that my router is not configed access internet via Internet port and provide it own DHCP. After re configed internet port... my 'facebook wifi' is successfully set up
