Prokur
Sep 22, 2016Follower
R6300v2 and Facebook Wi-Fi
Dear community, I just have bought Netgear R6300v2 to use it in my bar with Facebook Wi-Fi function. The latest available firmware V1.0.4.6_10.0.76 is installed, Guest access is enabled, but every t...
_R
Mar 13, 2017Initiate
Let me elaborate more.
(tl;dr: If you want a really working Facebook Wi-Fi solution, find an alternative, I've finally used a gateway from a cloud-manged brand, it worked really nice but I have to pay both hardware and yearly fee)
(Declaration: Not IT professional, now deployed FB Wi-Fi Solution from another brand instead, and my 6300v2 is now vacant)
Initially I checked Facebook Wi-Fi supported list showing quite some brands (some are pricey enterprise products, and some are more affordable/residential ones), among the list I chose R6300v2.
However, the Facebook Wi-Fi worked in a way -- Blocking Port 80 only and leaving all the rest ports opened, this is probably the laziest solution since almost no firewall rules are being touched, the router just tap 80 connection, moreover, since HTTPS is blocked and Facebook has been using a CDN (i.e. you can't determine what website the client is requesting), if they block HTTPS it will be too difficult to implement, so they left HTTPS (and other non-80 Ports) free. (Technical side: I think they just deploy a simple proxy server to divert all 80 traffic with a gatekeeper mechanism, non-80 traffic are directly routed out)
However, the world has changed a lot. Nowadays, most applications are using HTTPS as primary protocol (Google, Facebook, WhatsApp.... you name it!), even Google Chrome and some other browsers are prompting unsafe alert in non-HTTPS website, and under the current working mechanism, all these websites and services are freely accessible (without doing checkin/code/not even a button), not only HTTPS, if you got a VPN (Whatever, PPTP, L2TP or just SSH Tunneling), by connecting it you have jail-broken the walled garden, so the Facebook Wi-Fi feature is basically useless.
Well, Netgear is not the only brand that have such problem, you can enjoy non-80 port access other consumer brands (some enterprise brands, too) Facebook Wi-Fi routers.
The ultimate, technical way to solve this is implement a firewall-based mechanism, blocking all non-Facebook connection (regardless ports), the description in this open souce package has enough insight to make facebook IPs inside walled gardened (tl;dr: Cache DNS queries, and dynamically releasing IPs that matching Facebook/FBCDN domain names Reference: https://github.com/mhaas/fbwlan), the large memory and flash size is more than capable to incorporate such features. It's up to how much works Netgear would like to done. (Well, maybe it isn't Netgear's fault, if you look into GPL of R6300v2, FBWiFi part is precompiled, and you may notice other consumer-grade routers with Facebook Wi-Fi are all ARM-based, maybe it's Facebook's issue, but unlikely, it's rather someone not want to disclose the code)
If I have access to the official API on FB Wi-Fi, I would never buy this router.
rojarrolla
May 29, 2017Tutor
As everybody here, I have the same Issue, I have written Facebook and they don't reply. Even wrote Mark Zuckerberg, no answers either. Is there anything ? Or has this system ever worked before?
Thanks!
