Prokur
Sep 22, 2016Follower
R6300v2 and Facebook Wi-Fi
Dear community, I just have bought Netgear R6300v2 to use it in my bar with Facebook Wi-Fi function. The latest available firmware V1.0.4.6_10.0.76 is installed, Guest access is enabled, but every t...
DexterJB
Aug 28, 2017NETGEAR Moderator
Hi kazaven,
Please make sure that you are connected to the Guest Network and not to the main network.
Dexter
Community Team
DexterJB
Sep 04, 2017NETGEAR Moderator
Hi kazaven,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Jeff3755Sep 12, 2017Aspirant
FYI, I gave up after 2+ frustrating hrs on the phone with NG Tech Support plus shopping for the correct router. I did learn that it must be the R6300v2 on the box, not the AC1900 (R6300vw). None of the stores (BestBuy, OfficeDepot, Walmart, etc) sell the R6300 anymore. I bought one from eBay (new in a sealed box) only to learn that the factory installed firmware was for COX Internet and not useable for Facebook. Be careful what you buy and good luck with NG Tech Support.
- 2thmanSep 15, 2017Aspirant
Want to use FB wifi in my office - was going to upgrade my netgear router to R6300v2 (although would get the R6400 but site says no FB wifi), but after reading these suppport issues, forget it.
- btw, I called Netgear support and asian guy checked with someone who said 6400 does support FB wifi, but I see no documentation indicating that so looks like I'm going to ASUS
