Prokur
Sep 22, 2016Follower
R6300v2 and Facebook Wi-Fi
Dear community, I just have bought Netgear R6300v2 to use it in my bar with Facebook Wi-Fi function. The latest available firmware V1.0.4.6_10.0.76 is installed, Guest access is enabled, but every t...
kazaven
Aug 24, 2017Aspirant
I have a netgear r6300v2 with latest and when I set up the facebook wifi it allows me to connect and surf the internet but it doesnt require me to check into my selected facebook page. How do I fix this?
Jeff3755
Sep 15, 2017Aspirant
After getting no where with the Netgear, I went with the ASUS. The Facebook redirect worked in the Guest network however, it only seems to redirect on Android phones. There's a box in the configuration to add a code or "skip it". I chose "skip it" and it allows the Customer to do either. iPhones or laptops don't seem to redirect. Since I gave up on Netgear, I'm not sure if it's the same thing.
