Strugglin
Sep 30, 2016Aspirant
WNDR3400v3 N600 Wireless Dual Band Router password reset instructions don't work
I don't understand why when I ran antivirus software it alerted me I have a weak router username and password. I have set a new username and password and have clicked "apply." But when I follow the i...
- AnonymousSep 30, 2016
You're welcome
http://www.downloads.netgear.com/files/GDC/WNDR3400V1/WNDR3400_UM_31AUG2010.pdf
Password and passphrase are different ............one is for router security............ and the other is for WIFI security
Anonymous
Sep 30, 2016you cannot change router user ID .................. it's in the manual
- StrugglinSep 30, 2016Aspirant
Thank you for the help. I don't have the manual. So how to change password? Do I just change the "passphrase?"
You're welcome
