Strugglin
Sep 30, 2016Aspirant
WNDR3400v3 N600 Wireless Dual Band Router password reset instructions don't work
I don't understand why when I ran antivirus software it alerted me I have a weak router username and password. I have set a new username and password and have clicked "apply." But when I follow the i...
- Retired_MemberSep 30, 2016
You're welcome
http://www.downloads.netgear.com/files/GDC/WNDR3400V1/WNDR3400_UM_31AUG2010.pdf
Password and passphrase are different ............one is for router security............ and the other is for WIFI security
Retired_Member
Sep 30, 2016you cannot change router user ID .................. it's in the manual
Strugglin
Thank you for the help. I don't have the manual. So how to change password? Do I just change the "passphrase?"
You're welcome
