JerseyBiker's avatar
JerseyBiker
Devices losing connection on V1.0.4.30 firmware
I have a R7000 I purchased March of 2014. It's on 24 hours has worked without hardly any issues until the last firmware upgrade. I have many wireless devices including 2 Windows laptops, 2 Android tablets, iPad, 2 iPods, Android phone, iPhone, Panasonic TV, Denon receiver, Oppo Blu-Ray player and 2 printers. Since the firmware update many of my devices for no apparent reason lose connection. Not all of them at the same time but one at a time. No matter what I do I cannot get the disconnected device re-connected without re-booting the router. This an almost daily problem and I never know which device is next to lose connection. Should I try an older firmware or is there a router setting I should try. I appreciate any advice.
  • Did you factory reset router before and after upgrade? That's best way to ensure all of the fw upgrade works. Gets rid of any nasty artifacts (config or old fw realted) and loads any new drivers that may be included in a fw release.
    • JerseyBiker's avatar
      JerseyBiker
      You know I didn't think about that. It's not that I never knew about a factory reset but for some reason I just forgot. As a matter of fact I don't remember ever doing a reset on this router and I have had several updates. Well I'm going to do it now. I'll let you know in a few days if it resolved my issue. Thank you very much for the very fast reply.
      • dendman's avatar
        dendman
        Tutor
        I can verify the R7000 issue with the latest .30 firmware, very nasty bug it really hosed the network\router on the 5G side and affected overall performance...I had to revert to .28 to rectify and will not update until this is been fixed.
      JerseyBiker
      Netwrks I think you were correct. It's been almost 2 weeks since I did the factory reset and I haven't had any issues since. Even 5ghz which was acting weird not connecting at all sometimes casuing me to only use 2.4ghz is working OK now. I probably had 2 or 3 firmware updates without a factory reset. It's not something I'ts not something that I wasn't aware of,  I guess I just forgot about it. Thank you very much.
  • I have had an issue with the 5G side also with the newest firmware.  It drops the 5G connection on all of my devices (PC, iPad, iPhone, TV).  I have tried rebooting the router and unplugging the router which does not fix the problem.  Have done a factory reset before installing the new firmware and still having problems.  I don't have any problem with the 2.4G side.  Also intermittently loose connection to 3.0 USB hard drive connected to router.  Contacted Netgear Tier 2 technical support and they said they were not aware of any problems with the 5G dropping with the latest firmware.  I reverted to the previous firmware and the problem was resolved.  The Netgear tech suggested I replace the router to rule out a hardware issue.  They sent me another and had the same issue with the replacement.  I am sticking with the .28 firmware for now.
    • egiprime's avatar
      egiprime
      I reverted the firmware back to the previous version. It runs like it use to now with zero problems. It has not lost connection since. With the new firmware it would not stay connected and I would have to reboot the router each time to get the connection to establish and it would drop it after a few minutes.
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi egiprime,
        Please reset the router to factory default after the firmware update. Once reset has been done, reconfigure the router manually.
        JamesGL
        Community Team
  • I'm running V1.0.4.30_1.1.67 and did the factory reset and still have problems. Are you sure you did a factory reset, you might ask me? Yes I'm sure, I spent half a day reconfiguring.
    As of now I do not even see either my regular or guest 5G freq networks listed when I scan the airwaves, only the 2Gs. This is super frustrating. People told me I should buy an enterprise class router and not this consumer stuff and now I see why. Somebody really messed up in regression testing.
    On a separate topic, can Netgear please build their wireless channel scanning tool into the routers themselves, so I can see what are the clearest bands in my congested apartment building? I don't have an Android telephone so I can't run this tool Netgear recommends. Why isn't the capability to display channel usage built in? Go ahead, make fun of my Windows phone. I think I read Win Phone 10 has an API for a channel frq tool.
    Netgear please fix this firmware ASAP before I junk it and buy your competitor's product
    • JamesGL's avatar
      JamesGL
      Hi Cat6aPlease,
      Welcome to Community!
      Can you confirm if your devices supports 5GHz band? The reason that it will not detect 5Ghz as your devices might not be dual band.
      For wireless scanning tool, the Desktop genie has that feature which will show which channels are congested and which are clear.
      JamesGL
      Community Team
      • James,
        Thank you for the response, and I appreciate you have to deal with the lowest common denominator here, but the first question is insulting. The router is an R7000, so yes, it has 5G frqs. I mean it used to, before this untested firmware update broke them.
        Where in the "Genie" application can I find the congestion tool? This would be very helpful. I had to uninstall the Genie, because without asking me, it installed a media server. This gummed up my 4K TV, an excellent Sony XBR65X900B. That was very frustrating, and I spent more time figuring out where in the world this crapware "genie server" was coming from, because I never explicitly installed it (answer: Netgear Genie).
        Thank you and I do appreciate your response. Any updates on when a fixed firmware will be released?
