JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
- rogier64Luminary
After a lot of trouble with several late firmware versions for my R7000 (not stable, dropping WAN access frequently, 2.4GHz connecting issues, etc) I decided to flash an alternative firmware. I'm now using XWRT-Vortex based on AsusWRT-Merlin. I love it, absolutly stable and all issues are gone. First I was sceptical, tought it was a hardware issue with my router and was looking for a new one. For those who are desperate you can give it a try, you won't regret it. I'm on FW version R7000_380.69.
- MannyNAspirant
Same instability issues that other users have reported. Wifi connections just drop off for no reason (sometimes as frequently as 10 min after reset) and it is getting to be very annoying. Having to reboot the router everytime this happens. Seems to go offline even when no activity on the router. Have not been able to identify a pattern yet. Have devices connected to both bands, QoS is not enabled.
- decalphaGuide
I made the mistake of updating router to 1.0.9.18 from 1.7.x.
After the update none of the devices could connect to 2.4 GHz. And, one of my mobile devices only supports 2.4 GHz.
As a result, I tried R7000-V1.0.9.20_1.2.28 [BETA], but with same results.
Am currently back on 1.7.x, which is not a ideal situation but have no other choice.
Is there a stable firmware from 1.9.x series ?
What are other alternatives if any?
- Diggie3LuminaryNetgear, why don't you give us a test build without Disney Circle running? It was introduced around the time the firmware started going wonky, it's job is to interfere with traffic, and even when it's turned off it's still running on the box.
It would be interesting to see if a build with no Circle integration works okay. - decalphaGuide
Further to my previous message, I am trying V1.0.9.6_1.2.19. Things are looking fine since past 8 hours or so.
Not sure if I would again like to try higher version of the firmware.
- lepa71Guide
I want to add my 2 cents. I started having issues on 9.12 with connecting to my home server. I thought it was the server and I was at the point to re-built the server, then I decided I would check if there are any issues with the router and here it is. Downgraded to 9.6 and I'm back to normal. Netgear's FW is the problem again. I have been helping Netgear with R6250 by working with their 2nd and 3rd level support. They can give you a debug enabled FW and help you capture trace so they can analyze it. For people who got an email from Netgear and if you feel you are technical ehough, please try to help replicate the issue. netgear admit and pull out the bad FW as you have done it before. I understand you get money from Disney Circle, but if it makes problem in FW then drop it. Be transparent otherwise, you will get issues from consumer protection agencies and/or class action lawsuits.
- jomihiAspirant
Hi all,
using the 7000 as router and an EX6100 as repeater ... the same problem ... on 2.4 WIFI no stabel connection posiible (distance to big to check for a 5 GHZ connection)
Tests on a smartphone analyzer shows an permanent up and down on the signal stenght (after restarting the router it works well for some time, 20 min up to one hour or so...)
I watch this tread becouse it looks that many people have the same problem
BR Michael
- xrcdAspirant
After repeated attempts with new official firmware versions I have finally given up and installed Tomato. There is even a post about it on this forum https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-What-firmware-Stock-DD-WRT-Tomato/td-p/1279417 - it ends by "don't fix what isn't broken" but the current firmware for this router is well and truly useless.
Tomato seems to work fine so far. At least internet speed tests shows considerably faster throughput. For those who cares, there's a million parameters that can be played with. I haven't tested the gigabit lan speed yet, but if it doesn't require being rebooted every day to keep working I can live with whatever it is.
The irony is that hired staff from a big company like Netgear can not fix it, but some hobbyist tinkerers can.
- jomihiAspirant
Hi all,
reading all this stuff, i did following test: diabling all nice WIFI features like beamforce, auto channel, air time fainess, and did a manual straight forward setting yesterday evening. Till now i have a stable connection on 2.4 GHZ ...... lets see how long this last. However, I hope on an SW update very soon to get the nice things back.
BR
Michael
- HampelmanAspirant
Hi all,
I did the same as Jomihi did, turned of all fancy connecting features, but dissabled guest network and dowgraded to 1.0.9.6, as adviced by Netgear technical support from the Netherlands and have stable 2.4 for 4 days now.
Hopefully a temporary sollution!
Cheers,
Harmen
- Mattias__Aspirant
At this point i think my R7000 is leaving my house ending up in i bigger plastic container...
Are there any people here who have seen the same problems with other products from netgear?
Can't decide if i dare to buy another netgear or if i should go for something else.
- rogier64Luminary
Hi Mattias, I was completely done as well. My advice, try XWRT-Vortex firmware before recycling your R7000. I'm pretty sure you won't regret it.
- brianhelmanApprentice
I agree. 3rd party (Vortex) firmware is the way to go. I've just taken my R7000 out of service because I bought new hardware from another vendor, that also runs the Vortex firmware. My R7000 will be placed in another part of my house with the new firmware, either in a 3-dumb-router set up, or in AP-only mode. I haven't decided yet.
FYI, I had alread purchased the other router when I learned about the wrtVortex firmware. It is remarkably better. The interface and options are exactly what I wanted. I didn't realize how dated the stock R7000 GUI was, and I work on Enterprise Wireless all day!
I'm still very angry at Netgear for their (lack of credible) response to this whole problem, but the wrtVortex firmware certainly makes the R7000 acceptable again!
-Brian
- NukeJrGuide
This is a sad day but we need to candid. NG has seemingly abandoned the R7000 family. It should be an EOL router. Their focus right now is R8000+, Orbi, and Arlo.
The truth is NG will gain more customers from the previously mentioned devices than they will lose off this thread and mirrored ones across net-verse. I found the the R8000 for $179 on Amazon.
My concern is two fold: 1) that they are still selling a device that is known to be broken/defective. Linksys acknowledged their issue and at least tried to address it. 2) that serious investment in intellectual resources and support to remedy issues are nil once better models are available from NG. So be warned if you choose Arlo or Orbi once that ship has sailed.
NG seems to ignore the majority of us. Maybe I am wrong but it is still the impression I get based on my experience and what appears to be the majority on this thread.
In frustration I bought a Linksys and immediately had issues. I contacted Linksys and within moments they said it was a recognized problem and were willing to send me a loaner E8300 (don't know much about it) until they figure and rectify the issue, I said no thanx and returned the item.
After much more research, I begrudgingly opted for the R8000 and every issue I had, disappeared. I was receiving outstanding speeds (what the R7000 should have obtained but never did). I had no drops, no jitter, no lag. I was getting the same performance from my iMac on 5G from 30 feet away as my PC on ethernet. Virtually no discernable loss. Xbox was open for first time in years. Smart home and all devices work without issue or delay.
Unfortunately, it is not perfect. Outside of performance I do have some UI and management issues and my request for assistance have been so far ignored. I will call tomorrow with my list and go from there.
Bottomline, do your homework; check your budget; assess how you value your time, need, and frustration; finally, choose to jump to another capable vendor or 'upgrade' to another NG product (that may be ignored once it closes in on irrelevance to them down the road).
Lastly, I believe that regardless of FW, there are still issues. This appears to be a HW design flaw that has caused fruitless FW revisions trying to plug it up. It seems the internal aspects is somehow cancelling its own network (reflected out of phase 'ringing'?). They may have sold this product to meet schedule with either intent to plug hole later or discovered it shortly after release. My point-it will never be fixed to the point of its intended design.
- jmooremccAspirant
I've installed the following update to overcome problems with 1.0.9.18: R7000-V1.0.9.20_1.2.28_BETA. It has cleaned up a number of issues I'd encountered with the previous version.
- aabshireApprentice
Just to provide an update I received a debug firmware from Netgear and running it now to assist with debuging. Strange, I have been running this for almost 2 hours and have not had a dropped device since it started logging.
OK, I knew it wouldn't last (not that I expected it to with a debug version) but just dropped them
Update:I am still working with Netgear (I am sure others are also) in debuging and testing. I was provided new firmware from them late last night that they received from their chip vendor to capture more details.
They are working on this issue and attempting to correct.
- mad_professorAspirantI'm experiencing slowdown in download speeds/bandwidth with this firmware. I have 500mb/s service and can get ~521mb/s when connected directly to modem. Router downgrades service to ~260-280mb/s with this firmware.
- shoman94ApprenticeI turn off QOS and it fixed my speed shortcomings.
- mad_professorAspirantI have QoS disabled already.
After the update started having problems with 2.4Ghz, showing as connected on phones and tablets but unable to access the internet. Then 5Ghz joined in. Ended with no connection other than ethernet to PC.
Rolled back to earlier firmware and it's mostly ok but the PC just dropped the connection. I hope it was just a one off.
So Netgear, what gives?
- bunyan69Aspirant
This is getting frustrating. It would be nice if Netgear would give us daily updates. I dont expect a date for the next firmwae but it would be nice to see if any progress is being made. After this debacle I am another person who won't be buying Netgear again!
