softerist
Jun 07, 2017Apprentice
Hybernate External HDD of PLEX
Hello,
Is there any way that I could set up my external Western Digital connected via USB to my NETGEAR X10 router to hybernate or sleep, while PLEX or other proceses from him are not used?
My HDD is a little bit noisy and I can hear it all day and all night spinning in my room.
Thank you!
Ps. Sorry for bad EN.
Welcome to the community, softerist
Unfortunately, there is no setting on the router that would make your external drive to put on hibernate/sleep when not in use.
You may just safely remove it.
- softeristApprentice
Thank you for your answer.
I hope this will be implemented in the near feature.
- ElaineMNETGEAR Employee Retired
You're welcome.
I suggest that you submit it under our Ideas Exchange board.
