Aashrex's avatar
Aashrex
Internet goes away in 2.4Ghz a few times a day
I have a AC1750 wifi router and the internet goes away for about 2 minutes in 2.4Ghz band. Happens 2-3 times a day. I bought this router in 2021. Please suggest how to troubleshoot.
  • StephenB's avatar
    AC1750 is a speed rating - can you give us the actual model?
    Do you know for certain that the drop is only in the 2.4 ghz band?  Or is it possible that it effects 5 ghz, and maybe even ethernet?
    • Aashrex's avatar
      Aashrex
      Sorry, the device is R6350. It is only happening for the 2.4Ghz band.
      I have switched the bands to check if it was an internet issue. But 5Ghz was working fine. Problem only with 2.4Ghz
  • plemans's avatar
    What firmware are you on?
    What fixes the issue?
    Have you tried changing wifi channels?
    What actual router is it? Like StephenB​ says, you listed the speed, not the model.
    Tried the old factory reset/reinstall option?
    • Aashrex's avatar
      Aashrex
      Thank you for replying. The device is R6350. It is only happening for the 2.4Ghz band.
      I have switched the bands to check if it was an internet issue. But 5Ghz was working fine. Problem only with 2.4Ghz. I restarted the device and it was working fine. But the problem comes again after a few months.
      Current firmware version: v1.1.1.88
  • You should either downgrade or upgrade the firmware to a different version of firmware your router has. I've had routers be a little buggy with certain firmwares and once you change it, it begins working better.
    • Aashrex's avatar
      Aashrex
      Thank you for replying. Current firmware version: v1.1.1.88
  • plemans's avatar
    If the problems happen several months apart, I'd either reboot it once a month or reboot it whenever the issue occurs. That router is pretty old and several generations behind. So you can milk it along a bit, but I wouldn't invest any $ in repairing or parts for it. I'd keep it working for a bit while saving up for a newer one.
    To recover your login password, you can try the password recovery feature. If you didn't set it up, it'll still ask you the questions, but there won't be a correct response. If that's the case, you'd need to factory reset to get back in.
  • You can try downgrading firmware and see if it helps out cause most likely there isn't any new firmware for an AC1750 nowadays.
