mediatrek's avatar
mediatrek
Virtuoso
Feb 24, 2016
Netgear R7500 & R7500v2 need updated SSL Key in a firmware update
No this is not a "feature request" posting, but another highlight of Netgear not being ontop of their own "active" (not EOL) product line.
The original Netgear R7500 and the revision R7500v2 need firmware updates that contain the updated SSL key from Qualcomm Atheros to allow owners to access database updates for the Dynamic QoS (QCA Streamboost-based).
Without this update, R7500 and R7500v2 owners can only update the QoS database file to the one dated April 2015. Owners can not get the database update that was issued by Qualcomm in August 2015 and the latest from December 2015; not to mention any other database updates coming.
The new SSL key was added starting in the v1.0.0.28 firmware for the January 2016 released R7800. At best, users know that Netgear is months behind on getting this out to it's users as the new keys I am told were issued in the second half of Summer 2015 and here we are less than a month from the first day of Spring 2016 (March 20th).
  • ElaineM's avatar
    ElaineM
    Mar 18, 2016
    Per engineering, just update the QoS database and there's no need for any FW update to correct the SSL key.
    Can you guys confirm?
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi mediatrek Thank you for the feedback. Let me pass this along to our engineers and see what they say.
    I will update you as soon as I have a word.
  • Is there any update on this? The Streamboost feature was by far the top reason I purchased this router. I can overlook the numerous other problems with the router if this could get resolved. I understand that most of the issues simply can't be fixed, but this one thing doesn't seem like such a hurdle. Can Netgear just throw us a bone on this one, please? I'm close to going with another Streamboost-featuring manufacturer just to get Streamboost data that's not a year out of date. It seems like Netgear had thrown the baby out with the bath water with this series of routers. Their decision, I guess, but my credit card company didn't throw out the $250 I invested in this thing. I mean, I get it. This thing is a lemon. But at least fix the stuff that can be fixed. Don't just leave us stranded. We're still here. Thanks.
    • mediatrek's avatar
      mediatrek
      Virtuoso
      At first I was told: “Based from our engineers response, they have decided to discontinue creating any future updates for the 2 model numbers (R7500v1 and v2).” What?? The v2 just started shipping to retailers in October 2015!!
      Then a week later I was told: “It seems that we have a beta firmware that you could try.”
      I followed up on where things… and nothing. For this QoS issue I reported basically all Netgear engineering has to do is get the new SSL key from Qualcomm and compile the firmware for release. Nothing else has to change for this issue. It should take no more than 20 minutes for a semi-incompetent low-level engineer to do. A 20 minute task takes 2 week for the Netgear engineers apparently??? Maybe they should have their engineering teams working here in North America instead of over in China? I know a number of capable people they could hire.
      • WASTEDYOUTH's avatar
        WASTEDYOUTH
        Tutor
        That's a disturbing and ridiculous response. I can let the cessation of the v1 support slide, but, like you said, the v2 just released not long ago. Unbelievable. I actually had a positive experience with Netgear tech support when my first 7500 bricked. She was knowledgeable, easy to understand, and I had a replacement router in the mail either next day or second day. What you've been told is too much, however. I will cut my losses and look for another router that is actually supported and updated as promised. This was first Netgear product. It will also be my last.
  • The R7500v1 is EOL not the v2. As for you WiFi issues try downgrading the firmware.
    • Cstritt's avatar
      Cstritt
      The router itself doesn't say anything about the version but when I log into the firmware via router login.com it states R7500v2.  That is why I believe I have the v2.  Am I correct in this assumption?
      thank you for responding. I really do appreciate it.
      Cstritt
