B4D_WOLF's avatar
Sep 21, 2018
R9000 DROPPING WIFI EVERY 15-20 MINS
Neatgear Nighthawk R9000 X10
Firmware V1.0.4.12
QoS is already turned off (was never set up)
Wifi randonly drops off for about 30 secs about every 15-20 mins. This is mostly noticable on the 2.4ghz channel since all the "smart things" are connected to 2.4ghz. I have tried switching channels (1, 6, 11 & Auto) and hasnt seemed to help.
This only effects wireless connected devices as LAN devices have no issue.
I have had soo many issues with the new setup with the R9000 router and mesh (EX8000), I already returned the mesh to the store and plugged back in my EX7000 and I have been considering returning the R9000 and using my old R7000. I have had 4 hours of techincal support and still having more issues than with my old set up which was only replaced because I had to reset it once a week. Quite possibly my last netgear product.
  • Update:
    Nothing I tried fixed the issue and I got really tired of spending so much time trying to fix it that I returned it and made a switch to a different brand...
