lifequitin's avatar
lifequitin
Follower
May 21, 2015
Region change?
I bought R8000 from US during my travel and i want to use it within EU. Region setting can't be changed from admin interface and wireless performance is sluggish because of the low power compared to my home country. Is there any way to change region of this router other then US?
  • JamesGL's avatar
    JamesGL
    Nov 13, 2015
    Hi porschaman,
    The region is locked based on the place it was manufactured and also the firmware loaded on it. If you want  to change it, you may try loading a different firmware. Check the suppot site (Support.netgear.com).
    JamesGL
    Community Team
  • I live in IL and bought the Nighthawk r7000-100pas from Dell. (Don't offer 100nas) do I need to change anything and if so why don't they sell the North America version when most purchase in the USA? Thanks
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi kyd-GH,
      You can only change the region once you have loaded a firmware for specific region. You may visit support site for the firmwares.
      support.netgear.com.
      Hi Cognizant1,
      What is the region on the router's UI? If it is not North America then you can load firmwares for North America.
    • JamesGL's avatar
      JamesGL
      Hi Darshaannawab,
      Where did you purchase the unit?
      JamesGL
      Community Team
      • porschaman's avatar
        porschaman
        Please help! Recently purchased R6300v2 thru Amazon. The Genie's Region is locked on North America. Can you help me change it to Asia. Thank you all.
  • The reason why the region is greyed out because it is manufactured for the place where you purchase the unit. That is why there are different firmwares uploaded on NETGEAR's site for different region.
  • Sorry for posting so many replies, but i have found new information.
    Using the burnsku command,
    0x001 is for region NA
    0x002 is for region WW
    0x003 is for region GR
    0x004 is for region PR
    0x005 is for region RU
    0x006 is for region BZ
    0x007 is for region IN
    0x008 is for region KO
    0x009 is for region JP
    This are all the available commands i have found which links to a region. FYI, the numbers 0x001, 0x002 is the command you type in the telnet to change the region (burnsku 0x001 etc.)
  • Just a heads up, i only have these regions on the list currently:
    Asia
    Australia
    Canada
    China
    India
    Korea
    Malaysia
    Mexico
    Middle East (Saudi Arabia)
    Singapore
    South America
    United States
    If i right click on the box and inspect element, i could see other region's such as Africa, Europe, Israel, Japan, Russia and North America which has the line in front "Disabled". Editing the line makes the country appear in the list, but applying the setting results in the region resetting to "Select Region", which defaults as Europe (seen from the Advanced tab). Maybe this depends on where you bought it, maybe?
    Lastly, running the command
    wl -i eth1 txpwr1
    wl -i eth2 txpwr1
    wl -i eth3 txpwr1
    returns this:
    TxPower is 127 qdbm, 31.75 dbm, 1496 mW Override is Off
    I think that this states the maximum transmit power available for this router, but is limited via the country settings. I need someone to help check out on this too.
  • I managed to unlock the option to select the other countries available. Mine was locked on to North America at first (greyed out, can't select), but i managed to unlock it.
    If you need some instructions on how i did it, please tell me and i will post it. However, if you want to research on the instructions yourself, here are two things i did.
    1) Telnet into router using telnetenable (MyOpenRouter - even though the website says it is only for the Netgear R7500 and Netgear R7000, it works for my Netgear R8000 too)
    2) burnsku command to change the router's region to WW (world-wide)
    • 2022's avatar
      2022
      Tutor
      HI could you please send me the instruction to unlock the region
      for my XR700
    • kyd-GH's avatar
      kyd-GH
      Kindly give me the instructions to change my router region
  • Mine is greyed out, even if changed I do not know if this then also changes power settings.
