HanYol0's avatar
HanYol0
Slow Wifi Speeds Nighthawk x10
Just upgraded my router from the Asus RT-AC68U which was giving me my rated speed through time warner wired or wireless and now with this X10 i just set up today and installed newest FW as advised to, im only pulling in 50-60 down wireless but 330 down wired (normal speed).
-This is both on 2.4 and 5ghz
-I disabled my 60g AP
-reboot of router and modem which is the Arris SB6190
So far, dissapointed with the cost to performance of this router...ive check advanced setup for any limiting options enabled but nothing.
any ideas? not seeing any crossover talk from other routers in my area.
I upgraded to this just for sh*ts and giggles from black friday deal
  • Hi HanYol0,
    As long as the modem provides the correct speed from your ISP, then the router should be able to work fine.
  • FURRYe38's avatar
    What ISP Modem service link speeds UP and Down do you have?
    Did you perform a factory reset after the FW update and set up from scratch?
    What wireless modes are you using?
    Try Single mode N on 2.4Ghz and 5Ghz with WPA2 and AES only.
    What client device are you using to test wireless speeds?
    Were you seeing better results with the Asus router using same device?
    FYI regarding your SB6190:
    https://www.dslreports.com/forum/r31079834-ALL-SB6190-is-a-terrible-modem-Intel-Puma-6-MaxLinear-mistake
    https://www.dslreports.com/forum/r31122204-SB6190-Puma6-TCP-UDP-Network-Latency-Issue-Discussion
    • HanYol0's avatar
      HanYol0
      I have time warner oceanic here in HI and my speeds are 300+ down and 20 up.  I have not performed a factory reset after initial FW update no. Currently on the 5ghz link and both the 2.4 and 5ghz give me same download speed over wifi but as soon as i connect directly to router i get around 350 down and 22 up.
      Currently testing speeds with speakeasy and speedtest. My speed results with the asus router were 300+ down and 20 up as normal.
    • HanYol0's avatar
      HanYol0
      I have an SB6183 here as well and just hooked it up along with performing a factory restet on router and still <30mb down speed on wifi:(
      where do i find single mode N for 2.4 and 5 please?
    • HanYol0's avatar
      HanYol0
      So i changed the channel from auto on 2.4ghz to 2 and 6 each with speedtests in between and was about to get close to 200 down. Being on auto, is the limiting factor here interferance? 2 and 6 have to work together to provide my speed?
  • FURRYe38's avatar
    Set WPA2 and AES only with Speed up to 347Mbs and channel 11 then test on 2.4Ghz. I presume you don't have a client that can connect at 800Mb on 2.4Ghz, if not then leave at 347Mbs.
    • HanYol0's avatar
      HanYol0
      Thanks, i will try this out tom when i get home and follow up.
  • Stephen,
    That was the original problem but now I can't get above 100mbs down through a wired connection. This is with original router and r9000. Swapped sb6190 to 6183 thinking it was the culprit and nothing changed. Time Warner did checks on their end for signals and said everything was fine.
    Tech coming out Tuesday now but I feel like something weird is going on. I had good down speed with original Asus router and sb6183 before deciding to upgrade two weeks ago:(
    • FURRYe38's avatar
      If you have swapped modems and tested a different router, then I might presume there maybe an issue with your specific R9000 unit. Might try another one if you have a local store with a refund policy.
      HanYol0 wrote:
      Stephen,
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi HanYol0,
        If you connect the computer directly to your modem will you get the appropriate speed?
  • So I had time Warner come out since I couldn't get the 300 down speed direct through modem and wireless. They swapped out between my two modems sb6183 and 6190 and then put their modem on and speeds were erratic at first but then hit 320ish.
    So now on 5ghz I can hit above 320ish most of the time.. Wondering if maybe my ISP was secretly limiting my bandwidth..
    Are there any settings on this r9000 recommended to be left off?
    • JamesGL's avatar
      JamesGL
      Hi HanYol0,
