Tehcookiemonsta's avatar
Sep 02, 2015
Where is the ADSL Line Sync status on R7000
As the Title says, ive got to be missing it even though it seems like ive looked everywhere. i can't find the ADSL line sync page?
:smileyfrustrated:
  • Are you sure you have a R7000? It doesn't have an ADSL modem. It's a pure router.
    You may have a D7000. In that case the ADSL stats should be on the "show statistics" page reachable from the Advanced home page.
    • Tehcookiemonsta's avatar
      Tehcookiemonsta
      Just realised, that it can only be seen on the modem, my bad i'm still a noob at networking , although studying.
      My Modem router is bridged to my R7000 however i can't view the modem router after bridging it to the R7000. Am i also mean't to enable bridge mode on R7000
      • rpoffen's avatar
        rpoffen
        Virtuoso
        Once in bridged mode, you likely cannot see the modem itself, it is simply a translator for the DSL to ethernet. You must leave your R7000 in router mode though or you will not be able to login to your ISP (which probably uses PPPoE), nor will your clients be able to get an IP address (the R7000 is the DHCP server).
  • Many modem/router units will continue to have an IP address for management purposes. Often, it will use the same address before bridge mode was enabled. If you remember what it was, then try it.
    It may be possible to discover the address using a traceroute. On Windows, open a Command Prompt, and enter "tracert <ipaddress or hostname>". Use any Internet address or website. For example, "tracert netgear.com".
    If your modem has an IP address, it will often be displayed as the second hop in the tracert output.
      Tehcookiemonsta
      Hey , I tried traceroute, however the second IP is defintely not in my network. traced to google.com.au second IP 10.20.23.174 had 18ms
      First IP was the R7000 which i know.
      • TheEther's avatar
        TheEther
        Guru
        10.20.23.174 could very well be your modem's private IP address.  Try entering that address into your browser.
  • The default IP address used by the nb604n is 192.168.1.1. The R7000 uses the same address by default. You should change the R7000 to use a different IP subnet. Log into the R7000 and change its LAN IP address to 192.168.2.1 and click Apply. The devices connected to the R7000 will need to obtain new IP addresses, so either reboot or disconnect and reconnect them physically.
    Confirm that you can log into the R7000 by either going to routerlogin.net or 192.168.2.1. If that works, then try connecting to the modem at 192.168.1.1.
    If that still doesn't work then try connecting a computer directly to the modem thru one of its Ethernet interfaces and retry 192.168.1.1 or whatever IP address is listed as the default gateway by your computer. Alternatively, connect to the modem's Wi-Fi network, provided that it is still enabled. Then, connect to 192.169.1.1 or default gateway as before.
    If, after all, you still can't log into the modem, then rpoffen may be right that the modem cannot be accessed once it is switched to bridge mode. You may just have to live without knowing the DSL link stats.
    As a last resort, you can reset the modem to factory defaults by pressing the reset button. According to the nb604n user guide, hold it down for 3 seconds. This should revert the modem back to router mode. You should then beer able to log in and check the line stats. Then, enable bridge mode. It's painful but it should work.
      Tehcookiemonsta
      Hey, I plugged one of my pcs directly into the Modem and got an ip which worked thank you!
      However i tried to get onto this ip without being connected directly to the modem and it didn't work. I am on two different lans right?
      • TheEther's avatar
        TheEther
        Guru
        Yes, the modem is still maintaining a LAN for directly connected devices and is separate from the LAN behind your router.  As I mentioned before, you should insure that your router is using a separate IP subnet than the one maintained by the modem.  For example, if the IP address you obtained while plugged in directly to the modem was 192.168.1.X, then you need to reconfigure your router to 192.168.2.1.  Once you do this, you should be able to reach the modem from behind the router.
  • I'm running out of ideas. Does the WAN interface of the R7000 have a 192.168.1.X address? Or does it have a publicly accessible IP address? If it's the former, then bridge mode is not enabled, but you should be as able to log into the modem. If it's the latter, then perhaps the modem cannot pick out traffic destined directly for it (I.e. you can't log into it from a device behind the R7000).
      • TheEther's avatar
        TheEther
        Guru
        When you log into your R7000 and click on the big Internet panel, is the Internet IP Address something like 192.168.1.X or something else?  If it's something else, don't post it here or only provide at most the first two numbers.
