johnnyboy98
Jun 28, 2024Aspirant
Rs300 internet not working on virgin hub 5 in modem mode
I've just got the rs300 and when I've connected the cable to my hub 5 that is in modem mode the rs300 will not connect the indicator light shows orange but when I move the cable to another port it works fine.
Just want to know if anybody else has this problem and does the rs300 randomly disconnect for anyone else
Also had the rax500 and that worked no problem connect to the 2.5g port in the virgin hub.
Would really like to know
Thanks john
Thanks john
What kind of CAT# LAN cable are you using between the RS and ISP modem? CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.- johnnyboy98AspirantHi
Ye I'm using a cat 7 cable and I've turned the virgin hub on and off and still not working, as I say when I move it to another port on the virgin hub it works fine. I'll give it another try in the order you've said and see what happens.
Thanks john
Did you find this?
Hub 5 in modem mode - Virgin Media Community - 5474880
Different router, but similar issue.
More here!
virgin hub 5 in modem mode - Google Search
But you probably tried that.
At least Virgin offers a modem mode, unlike BT and its nasty HomeHub.
Thanks for the reply
Just had a look at the fourms and done all of that ,still getting this orange light, doesn't seem to like the 2.5g port on the virgin hub. I don't know if it's some sort of a unknown bug on the rs300 also been disconnected randomly off the WiFi 7 band. I'll go on the virgin forums to see if it's an issue with their hub.
Agreed at least they let you put it into modem mode but their new hub5x doesn't have the feature yet.
Thanks again
John- FURRYe38Guru - Experienced User
Any progress on this?
johnnyboy98 wrote:
Hi
Thanks again
John
