MrChrisH's avatar
MrChrisH
RS700 VPN Service certs incomplete?
I've been setting up NoIP and the VPN Service on my RS700. I'm on firmware version V1.0.9.6_2.0.100.
After much tinkering and following much of the helpful advice here, I have a connection that works. However, I am getting this error in the log, which I have seen others post about but update the firmware seems to be the solution(?). I'm on the latest firmware.
Thu Oct 23 17:12:39 2025 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
When I add remote-cert-tls server to my .ovpn file, which in my understanding is good practice to include, my connection fails:
Thu Oct 23 17:15:09 2025 Certificate does not have key usage extension
Thu Oct 23 17:15:09 2025 VERIFY KU ERROR
I've stopped started the VPN Service multiple times, re-copied the config files etc but can not get the connection working with remote-cert-tls server in my .ovpn file.
The certificate provided by the router seems to be missing the necessary Key Usage (KU) flags.
How do I fix this, please?
  • CrimpOn's avatar
    CrimpOn
    Thanks for the update.  If by chance you test OpenVPN on the new firmware, it would be helpful to hear the results.
    There are other methods to provide remote access to the LAN, such as installing Wireguard on a local computer or purchasing a device that supports OpenVPN/Wireguard.
    I have not investigated whether other methods trigger warnings similar to this one.
  • CrimpOn's avatar
    CrimpOn
    MrChrisH​
    If you learn something useful and are allowed to 'share', please update the conversation.
    I notice the same WARNING about certificate verification method when using OpenVPN with my ancient Orbi system. (Opened a VPN connection just now)
    I wonder if this could be a situation similar to the frustration we all experience with modern web browsers issuing similar warnings about the web interface of the router itself.  i.e.
    • If we connect using http, browsers warn UNSAFE, because by definition http is not encrypted and thus "unsafe".
    • If we connect using https, browsers warn UNSAFE, because the SSL certificate is self-signed and thus there is no "God Like" certificate authority guaranteeing that this SSL certificate belongs to the organization claiming it.
    These warnings, of course, overlook the plain fact that WE deliberately CHOSE which web site for the connection (our own router, on our network).  We did not get a link from some site on the internet or from a suspect email.
    In a sense, our use of OpenVPN is similar.  WE chose to open a connection to this specific IP address (or DDNS address) and we are exchanging Keys that WE created using OpenVPN on our router.
    For YEARS, I have simply ignored that OpenVPN warning when using OpenVPN.  If there is a simple method to (a) make the warning disappear and (b) improve security, I'm all for it.
    • MrChrisH's avatar
      MrChrisH
      CrimpOn​ thanks for your message.
      Yes, you might well be correct and I could have been over thinking this! When seeing warnings re security I do like to triple check what they are indicating.
      I have since found a different approach for my needs and decided to not use Open VPN. Part of that was due to me not fully understanding the possible risk I was being warned about by Open VPN.
      Additionally, for my RS700 router, Netgear have released a new version of the firmware (V1.0.10.8 - from here https://www.netgear.com/support/product/rs700s ) which may (I have not tested) contain a fix that addresses this.
  • StephenB's avatar
    Are you seeing a section like this in client.crt?
                X509v3 Extended Key Usage:
                    TLS Web Client Authentication
      • StephenB's avatar
        MrChrisH wrote:
        No. I'm not seeing a section with that header.
        That is why you have the problem.
        FWIW, I missed a second relevant line from my client.crt (from an Orbi, not an RS700):
                    X509v3 Key Usage:
                        Digital Signature
        Only Netgear can fix this, as adding this text would invalidate the cert's digital signature.
        All you can do for now is remove remote-cert-tls server.
    • MrChrisH's avatar
      MrChrisH
      Thanks for checking, yes, I'm on firmware version V1.0.9.6_2.0.106. I updated fw again this AM, as I noticed a very recent new version, and reconfigured openvpn and downloaded config files from the router.
      I still get the "Certificate does not have key usage extension" error and the connection fails when I include remote-cert-tls server in my config.
      • FURRYe38's avatar
        FW version should be v.16 though. Can you confirm this?
