robrub's avatar
robrub
Tutor
Mar 08, 2015
BUG: ReadyCloud install error
Hi
Just found out this little bug. On a Windows where you have changed the temp directory place in the system variables settings (Temp and Tmp point at c:\tmp on my computer) and you install ReadyCloud, the software decompresses files in the correct tmp directory (c:\tmp) but when the install needs to read the decompressed files, it searches in the "usual" windows temp directory (from memory c:\users\blablabla\temp).
The install stops and asks where it can find some files (like ??stuff or similar). Sorry, I did things without noting the exact files. If you show it where the files are, install goes on as it should.
I suppose the temp path ws read from the system to uncompresse the files but was hard coded to read the results.
ProSupport for Business
