funkygecko
Nov 14, 2016Aspirant
Can't connect to ReadyCLoud, but connects to Raidar...
Ive had my ReadyNAS 102 for a few years and its worked fine. I have it setup to link directly through ethernet from Rn102 to my iMac. I have the unit setup with Time Machine for my backups, and a mon...
Nov 14, 2016Guru - Experienced User
You can start over w/o using readycloud. Can you access the web UI directly?
- funkygeckoNov 14, 2016Aspirant
Not sure how to do that...
- mdgm-ntgrNov 14, 2016NETGEAR Employee Retired
Which firmware is the RN102 running?
Is the correct serial number showing for the RN102 in RAIDar? If not that will need to be fixed before you update to 6.6.0. - StephenBNov 14, 2016Guru - Experienced User
https://nas-ip-address/admin
You should be able to see the NAS iip address from your router.
- baboonenNov 15, 2016Aspirant
I have the same issue. Can see my NAS with raidar, but not with ReadyCloud. I've changed the name of my NAS in the past. When I try to register it again the process fails, because I already registered my NAS. When I turn the feature ReadyCloun on it says the services are offline. Who can help me?
Regards Bobby
