funkygecko
Nov 14, 2016Aspirant
Can't connect to ReadyCLoud, but connects to Raidar...
Ive had my ReadyNAS 102 for a few years and its worked fine. I have it setup to link directly through ethernet from Rn102 to my iMac. I have the unit setup with Time Machine for my backups, and a mon...
funkygecko
Not sure how to do that...
mdgm-ntgr
Nov 14, 2016NETGEAR Employee Retired
Which firmware is the RN102 running?
Is the correct serial number showing for the RN102 in RAIDar? If not that will need to be fixed before you update to 6.6.0.
