speedliner
Oct 22, 2015Guide
Changed NAS102 to static IP and ReadyCloud reports no registered devices
Hi Folks,
This is probably a simple fix, but I can't find a parameter or existing entry to help get me back on track. I recently setup a new RN102 and all was working fine including maped desktop drives to the NAS shares. Then it all stopped working one day and I realized that was because IP address changed after a reboot of the NAS. So I changed the network config to a static IP address. That went fine and I can log into the NAS and all seems fine there.
The problem that I can/t fix is that ReadyCloud on my desktop, and the cloud portal report the error "Currently you have no registered devices." Well, I do and it was all working fine two days ago. I assume that ReadyCloud remembers the original IP address somewhere, but I can't find any documentation regarding how to correct this.
Any help appreciated. I'm new to NAS and out of ideas and interface tabs to click.
Thanks,
Rob
Did you remember to set the DNS server addresses when you changed to static IP addresses?
Often people forget to do that (its on a different tab), and it will cause the problem you are seeing.
FWIW, its better to use address reservation in the router, and keep the NAS set to use DHCP.
Yes, I did set that to the router's address.
Try checking for a firmware update, and see if it can find the server.
You can also try 8.8.8.8 as the DNS server address, and see fi that resolves it.
